Contributor II
AP Flag 2D and 2ID
We are with some APs with Flag 2D and 2ID in AP Installation.
Have an easy way to fix it without reset the AP by console (hard access to AP)?
Controller running 6.3.1.21
Regards;
Re: AP Flag 2D and 2ID
Looks like you have CPSec enabled. Did you add the APs to the CPSec whitelist?
Tim Cappalli | Aruba Security
Contributor II
Yes. But "Auto Cert Provisioning" is enabled and "Addresses Allowed for Auto Cert" are with "all".
Maybe if I disable it can be fixed?
Do a show log system 100
Contributor II
in attach
