Frequent Contributor II
AP Group SSID report
Is there a way to view all the SSIDs associated with a/all AP group?
I've done it manually, but i was wondering if there was a CLI way of viewing all the ssids being used by every AP group.
Re: AP Group SSID report
This might not be exactly what you're looking for, but might come close:
- show wlan virtual-ap
Will show all of the VAP-profiles and the reference count for each VAP-profile.
- show references wlan virtual-ap <profile-name>
Will show the references for a specified VAP-profile
ACMX#255 | ACDX#742 | ACCX#746 | AMFX#25 | ACMP | ACCP | AWMP
www.securelink.nl
if you do show ap essid does it give you what you want?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
