AP Instant 225- not showing Provisioning SSID? (2 units)
New to the Aruba instant APs, and I did search the forums without hitting on the answer. I have two new APIN0225s- with AC power adapter. When I plug in, by the Quick Start, shouldn't I see the "instant" provisioning SSID? (I do not, for either). Is there another controllerless way to bring these up? Waiting for response on my cloud eval request, but the Instant APs can run completely stand-alone, yes?
I'm in on the console, but not wanting to create more problems.
Thanks-
Lee
Re: AP Instant 225- not showing Provisioning SSID? (2 units)
Are these getting an IP address ?
Thank you
Victor Fabian
Lead Mobility Architect @WEI
according to console, yes.
18:64:72:c5:3e:38# sh ip interface
Interface IP Address / IP Netmask Admin Protocol
br0 192.168.1.114 / 255.255.255.0 up up
-Lee
Super Contributor I
Yes, the IAP can run as standalones and you should see the instant SSID. If you do not see it can you try to reset it, it should have a reset button, else you can try going into the AP via the IP address you had gotten. Try 1 AP at a time.
Normal Guy
OK- SSID showed up, after about 45 minutes. Sorta odd- monitoring with multiple devices for sanity. I'm rocking and rolling- thanks very much for the responses.
-Lee
Having a similar issue with my 225. I'm powering it via POE+, power light is blinking green which means "powering up", enet0 is rapid blinking as it is having activity, but the rest of the lights (namely 5ghz and 2.4ghz) are off. I remember reading here that it took him 45 minutes before it came up, I think I've had it for well over that.  Instant SSID is still not showing up.  Aside from a hardware fault, anything else I can look at?
