Frequent Contributor I
AP Management lockdown
We have 4 subnets that we use for AP Management (4 core Cisco routers, and each has several buldings/APs hanging from). I would like to lock the subnets so that even if a student decides to unplug the path cord from an AP and plug their laptop, they would not be able to go anywhere. So I crafted this ACL (below). The problem I have is that it does not allow APs to get a DHCP address, however, the laptops can. Our APs get DHCP by DNSing aruba-master, so I allowed DNS and DHCP in the first 2 lines. This ACL is blocking outgoing traffic from the APs point of view and is placed on the subnet interface on the router:
ip access-list extended wireless-AP_Mngmnt-lockdown-UTS
permit udp any eq domain any eq domain (DNS lookup to find the controller)
permit udp any eq bootpc any eq bootps (DHCP request)
permit ip any host 130.253.21.25 (controller)
permit ip any host 130.253.21.26 (controller)
permit ip any host 130.253.21.27 (controller)
permit ip any host 130.253.253.100 (Cisco Works, we have some switches on this subnet)
permit icmp any 130.253.0.0 0.0.255.255 (ping APs from our network)
deny ip any any
Any ideas? Do the APs do anything “funny” when requesting DHCP?
Thanks!
Marcelo Lew
Wireless Network Architect-Engineer
University of Denver
Re: AP Management lockdown
I added a line for broadcasts and now the AP is getting an address. But seems it can't form the GRE tunnel to the controller, so I allowed GRE on the ACL. But still can't talk to the controller:
permit ip any 255.255.255.255 0.0.0.0
permit gre any any
deny ip any any
Marcelo Lew
OK, I have it working this way. I had to open all UDP ports, because looking at the datapath sesion table it was picking some random (non-well known) ports once in a while, table below. So this is what my ACL looks like, not a 100% bulletproof, but good enough for the casual student deciding to try connect his computer to an AP port/patch cord:
permit udp any any
permit gre any host 130.253.21.25
permit gre any host 130.253.21.26
permit gre any host 130.253.21.27
deny ip any any
(Aruba6000-UTS-master) #show datapath session table 130.253.90.146
Source IP Destination IP Prot SPort DPort Cntr Prio ToS Age Destination TAge Flags
130.253.90.146 130.253.21.26 17 8211 8211 0 0 0 0 local 7 F
0 0 0 1 local FY
130.253.90.146 130.253.21.25 17 8211 8211 0 0 0 0 tunnel 8 7 FC
0 0 0 1 tunnel 8 FYC
130.253.90.146 130.253.21.26 17 2049 123 0 0 0 1 local c FY
0 0 0 1 local FY
130.253.90.146 130.253.21.25 17 2049 123 0 0 0 1 tunnel 8 c FC
130.253.90.146 130.253.21.25 17 2049 514 0 0 0 1 tunnel 8 b FC
130.253.90.146 130.253.21.25 47 0 0 0 0 0 0 tunnel 8 4 FC
0 0 0 0 tunnel 8 FC
130.253.21.26 130.253.90.146 17 51959 2 0 0 0 1 local 7 FC
0 0 0 0 local FC
130.253.21.26 130.253.90.146 17 8211 8211 0 0 0 0 local 7 FC
0 0 0 1 local FYC
130.253.21.25 130.253.90.146 17 8211 8211 0 0 0 0 tunnel 8 7 FY
0 0 0 1 tunnel 8 FY
130.253.21.25 130.253.90.146 47 0 0 0 0 0 0 tunnel 8 4 F
0 0 0 0 tunnel 8 F
130.253.21.25 130.253.90.146 17 123 2049 0 0 0 0 tunnel 8 c FY
0 0 0 1 tunnel 8 FY
130.253.21.26 130.253.90.146 17 123 2049 0 0 0 0 local c FC
0 0 0 1 local FYC
130.253.21.25 130.253.90.146 17 514 2049 0 0 0 0 tunnel 8 b FY
0 0 0 1 tunnel 8 FY
Marcelo Lew
Firewall elements to open
Appendix B (page 591) of the ArubaOS 3.4 user guide has all the protocols you would need to open.
Colin Joseph
Aruba Customer Engineering
Guest Blogger
Re: Firewall elements to open
Isn't it easier to configure wired authentication based on 802.1x on the switch ports? That way you know that an unsecure client never gets any access to the network by placing them in a quarantine / internet-only environment.
OOPS: didn't see that this post already is VERY VERY VERY OLD!!!
@rene_booches | AMFX #26, ACMX #438, ACCX #725, ACDX #760, CCNP R&S, CEH | Co-owner/Solution Specialist@4IP / blog owner@booches.nl
