AP NOT JOINING TO 7720 CONTROLLER
I have a 7220 controller and i'm configure dhcp server on 5940 switches
ap getting a ip but not join on the controller.
when ap get the ip i'm ping the ap ip from the controller and its reachable.
Kindly provide the solution.
Contributor I
Re: AP NOT JOINING TO 7720 CONTROLLER
Did you disable CPSEC or whitelist the ap's?
Are the aps connected to the same L2 VLAN as the WLC?
Did you use option 43 for discovery of the controller?
mkk
Contributor II
How does the ap discover the controller? Statis, dhcp option43/60, adp broadcast or dns (aruba-master)?
Be sure cpsec auto certificate deployment is enabled.
Be sure you have the correct licence count
Please aware that the accesspoint gets a gateway in the dhcp response. The ap must have a gateway even in a layer2/same vlan deployment to discover the controller through ADP.
actually i'm configured dhcp server on hp 5940 switch on Vlan-3
and my controller on vlan -2 but all vlans allow to trunk port.
so tell me where i need to configure option 43 for discovery of the controllers
Frequent Contributor II
Unless your AP and controller and AP are in same L2 domain, you need to configure option 43 (or can statically configure controller IP on the AP) on your DHCP scope. Below link may help you:
https://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/DHCP_Option_43.php
JayBee
ACDX | ACCX| CCIE (RnS/SP,DC) | ACCP | ACMP | ACSA | ACMA | JNCIS | JNCIA
If the provided solution resolves your issue, please mark it as accepted solution to help others.
the above link for windows base dhcp server actually i don't have widows dhcp server so thats why i'm configured the dhcp server on HP5940 switch.
so you please tell me how to configured option 43 on HP 5940 Switch.
can you tell me how to configure optin 43 on hp 5940 switch because i'm configured the dhcp server on HP switch
I did the search here:  https://www.google.com/search?q=hp+5940+dhcp+option&rlz=1CAASUL_enUS778US778&oq=hp+5940+dhcp+option&aqs=chrome..69i57.21190j0j7&sourceid=chrome&ie=UTF-8 and click on the first link.
The first link is here:  https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c03187006 and I saw this:
Please use in the instructions here on what opitons to configure:  https://www.arubanetworks.com/techdocs/ArubaOS_60/UserGuide/DHCP_Option_43.php
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
i'm configured the option 43 with following command:-
[HPE-dhcp-pool-WIFI-MGMT-VLAN]option 43 ip-address 172.16.0.10 172.16.0.11
[HPE-dhcp-pool-WIFI-MGMT-VLAN]display this
dhcp server ip-pool WIFI-MGMT-VLAN
gateway-list 172.16.4.1
network 172.16.4.0 mask 255.255.252.0
address range 172.16.4.2 172.16.7.252
option 60 ascii 'ArubaAP'
return
but ap not join the controller
Please try it with only a single ip address in the DHCP option 43.
