Re: AP NOT JOINING TO 7720 CONTROLLER
I'm try this only a single ip address in the DHCP option 43.
but still same issue happening.
[HPE-dhcp-pool-WIFI-MGMT-VLAN]display this
dhcp server ip-pool WIFI-MGMT-VLAN
gateway-list 172.16.4.1
network 172.16.4.0 mask 255.255.252.0
address range 172.16.4.2 172.16.7.252
option 43 ip-address 172.16.0.10
option 60 ascii 'ArubaAP'
return
AP Console Information:-
Starting watchdog process...
LLDP not sent yet, DHCP is waiting
Starting DHCP
Getting an IP address...
172.16.4.2 255.255.252.0 172.16.4.1
Running ADP...cat: /tmp/master: No such file or directory
Done. Master is
killall: nanny: no process killed
killall: sapd: no process killed
AP not getting Controller IP.
Please tell me any remedy
Looks like the AP isn't seeing those options in the DHCP Offer so it moves on to ADP discovery. Do you see the options if you run a packet capture? Are you also able to ping the controller from the AP?
As a test you can always statically set the controller IP using the below.
setenv master x.x.x.x
setenv serverip x.x.x.x
ACMA, ACMP, ACSA, ACDX #985
If my post addresses your query, give kudos:)
