AP SNMP System Location not present in Airwave
We are currently monitoring Aruba APs using Airwave 8.2.3.  AMON and SNMP ver 2.  The issue we are experiencing  is the AP Location field is not being populated from the AP SNMP System location field from the controller.  Any ideas why this is not working?
Re: AP SNMP System Location not present in Airwave
We have the location field only under the monitor page for the controller and not for APs. Could you confirm whether you are not seeing it for the controllers as well?
Controller monitor page
AP Monitor page
Vishnu
If my post helped you, don't forget to give kudos ;)
Below is what I'm refering to.  There is no Location information for either APs or controllers.
Got it. In this for APs it wont be showing, as we dont have the location field if we navigate to AP monitor page.
For controllers could you share a screen shot of the sys location set on the controller web interface? Also, please share the output for below snmp walk from Airwave CLI,
# s2w <Controller IP>  <Community string> sysLocation
Vishnu
I take it the location field was removed in 8.2.3 because version 8.2.0.1 has it.  Example of this below.
