Contributor I
AP and Antenna combination for warehouse with 80' ceiling?
The ceiling is so tall in this environment I figured it would be better to mount on the collumns which divide this large warehouse into 5 north-south bays.  After reviewing the AP matrix, with current end-of-life notices, it seems the AP 11x is the best choice.  The only issue could be the 115 has a built-in downtilt Omni, so it might be a better option to go with an AP-114 with three AP-ANT-1B antennas to get a true omni.
The 114 is ok with 802.11af power, which saves on power injectors, but does require 6.3.1.0 code.
Thoughts?
MVP
Re: AP and Antenna combination for warehouse with 80' ceiling?
Our ceilings are 35-45 feet (depending on warehouse) and we're quite happy with the built-in antenna APs and their downtilt.
We're using 93 and 105 -- haven't had the opportunity to install anything newer yet.
--Matthew
if I've helped, please give kudos
if I've provided a solution, please mark the solution so others can find it
Contributor I
Yep, that was the last stuff I installed too.  Since the old 93 and 105 are basically end of sale/being phased out, I want a new solution that has some shelf life.  At 80', this ceiling is going to be a tough one.
