I have controllers running 6.3.1.4 - FIPS. I need to determine if the Aruba 215 WAPs are compatible eith this version or if the controllers require an upgrade first. Where can I access the compatability guides?
Check the AP data sheets for minimum OS support. You can also go to http://www.arubanetworks.com/products/networking/access-points to look at and compare products and it will list minimum OS support required.
