AP and GRE Tunnel
  • 1.  AP and GRE Tunnel
    Posted Feb 10, 2014 09:50 AM
    Hi i want to know if it is possible that an AP made an GRE tunnel to differents  controllers based on the choosen SSID by the client. For example:
    Controller A is the end of the GRE tunnel when the SSID A is choosen and controller B when the SSID B is  choosen.
    Best Regards
  • 2.  RE: AP and GRE Tunnel
    Posted Feb 10, 2014 09:53 AM
    That cannot be done, unfortunately.  An access point can only have a GRE tunnel to a single controller.  Why not put a layer 2 GRE tunnel between the two controllers and MAP the VLAN B to the tunnel, so that the user traffic would effectively end up on controller B?
  • 3.  RE: AP and GRE Tunnel
    Posted Feb 10, 2014 10:00 AM
    Thank you for this answer.
    Actually, i just want that the trafic ends on controller B when the choosen SSID is B. I guess your solution will be OK. Can you give me the steps needed for this configuration in details please.*
    Thank you again.
  • 4.  RE: AP and GRE Tunnel
  • 5.  RE: AP and GRE Tunnel
    Posted Feb 10, 2014 10:32 AM
    Thank for the answer.
    Just one last question: For The licence, controller A and B show have the same licence or not?
    Thankx again.
  • 6.  RE: AP and GRE Tunnel
    Posted Feb 10, 2014 10:40 AM
    You do not need a license for any controller that is not terminating access point traffic (Controller B).  If you have other access terminating on that controller, you need licenses for those access points.
  • 7.  RE: AP and GRE Tunnel
    Posted Feb 10, 2014 10:41 AM
    Thankx
