Rye
AP and controller are on different sites.
Hi All,
Can someone help me regarding this case.
The controller and AP are on different site, they are connected via MPLS. They can ping each other but the AP is not able to synch with the controller. What could be the possible reason and solution for this issue? Any suggestions will be much appreciated. Thank you!
Re: AP and controller are on different sites.
