Super Contributor II
AP converting AM
We have deployed AP105 in an office.  all the system is working perfectly fine.  but sometimes one or two AP's convert to AM may be due to interference.
How can we stop this behavior. i mean we dont want AP's to convert themselves in AM. how can we do that.
Please also note that we have RFProtech licenses installed in controller
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
MVP
Re: AP converting AM
[ Edited ]
Configure your ARM profile and disable:  Mode aware ARM
Mode aware ARM is used to turn of access points where there is too much coverage so that additional APs on the same channel cause less interference. If you are not overdeployed to the point of having interference, you should NOT use mode aware ARM.
Thank You
Thanks & Regards
Syed Murad Ali
ACMP ACMA CCNA
