Contributor I
AP does not take IP address
When I connect the faulty AP to my Laptop through console cable I get the following
Hit <Enter> to stop autoboot:  0
apboot>
apboot>
apboot> dhcp
en0:    Down   1Gbs Half duplex, (port  1)
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
Retry count exceeded; starting again
en1:    Down   1Gbs Half duplex, (port  0)
BOOTP broadcast 1
en1: Down   1Gbs Full duplex, (port  0)
en1: Up     1Gbs Full duplex, (port  0)
BOOTP broadcast 2
BOOTP broadcast 3
 BOOTP broadcast 4
BOOTP broadcast 5
en0: Down  10Mbs Half duplex, (port  1)
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
BOOTP broadcast 4
BOOTP broadcast 5
in case of autoboot i got the following error
eth1: Link down secure_jack_link_state_change: Error finding device eth1
PCI ERROR[MR_WABT]: PCI master abort detected on write.
 bonding: bond0: link status definitely down for interface eth1, disabling it bonding: bond0: now running without any active interface ! PCI ERROR[MR_WABT]: PCI master abort detected on write.
eth1:   1Gbs Full duplex, port  0, queue  0
eth1: Link down
eth1: Link down
M. Alajeely
Re: AP does not take IP address
What version of ArubaOS Code is this and What AP Model?
Contributor I
AP 125
I'm not sure about OS version, i'm not in my office to check it.
i've tried to assign static IP address and default getaway, it was OK and I was able to save the configuration
but the interface go's up and down, so I could not ping my controller or even getaway
M. Alajeely
You should open a support case based on that output.
