gjo
AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
Hi
I just upgraded my controllers from 6.1.2.2 -> 6.1.2.5
All Campus AP's came up without any problems, but all RAP's entered a loop, where it reboot,s and then start upgrading again.
This happens both with RAP5, RAP2, and AP61.
Any ideas how to solve this ?
Jone
Re: AP enters upgrade loop after controller upgrade 6.1.2.2 - 6.1.2.5
Type "show log system 50" to see why those RAPs are rebooting.
Are you using PPPoE?
Zach Jennings
Frequent Contributor II
Hi
I just upgraded my 620 controller from 6.1.2.4 to 6.1.2.5 and RAP-5 goes in a loop, not able to upgrade.
I use PPPoE on the interface that holds the public IP.
So it seems that it is a common problem.
gjo
Hi
Sadly, There is not much info on my controller about reboot reason. I will bring one of my RAP to my office today and look at the AP, what it's doing.
I have verified that it is happening on AP61 (as RAP), and also on RAP-2.
I also think it is happening on RAP-5.
Vil verifiy today.
Please check AP-ROLE and make sure FTP is allowed there.
I would recommend you to open a TAC ticket to debug the issue.
To troubleshoot the issue, here is what I would check:
1. session on port 4500 from RAPs outer ip. You cn check this in datapath session table.
2. If session is there , that check for "show crypto isakmp sa" from CLI enable mode.
3. If it is there, check for "show crypto ipsec sa". Also check Inner ip-address of the RAP here.
4. Do "show user-table verbose" and see whether RAP is in the AP-Role or not.
5. From the inner IP address of the RAP. check datapath session on port 21 (FTP), 8209 (Sec-PAPI).
Hope this will help.
Any news on this problem? I am facing the same issue.... start a endless upgrade process and reboot. I pressed reset to clear the configuration and the RAP5  has 3.3 version before the upgrade begins.
any idea?
thank you
Rodrigo Piovesana
Roderigo, you must do the procedure here:  http://community.arubanetworks.com/t5/Command-of-the-Day/COTD-apflash-backup-partition-or-how-do-I-upgrade-my-RAP5/m-p/5829/highlight/true#M258 before trying to upgrade to 6.x
