Contributor II
AP fast failover-Controller
Hi all.
I have a question with AP fast failover feature.
In a architecture of Master/local I can do AP fast failover/VRRP/Backup LMS for Local high availability and VRRP for Master high availability.
But if I have a architecture of centralized controller without Master/local, only two standalone controller, can I do AP fast failover with standalone controller?
MVP
Re: AP fast failover-Controller
If there isn't a second controller to failover to, then no, you can't do any failover, let alone fast failover.
Koen (ACMX #351 | ACDX #547 | ACCP)
Contributor II
I know that, but I mean If I have TWO controllers without Master local.
Can I do Fast failover between them?
MVP
Right, my bad. Thought it was a bit simple question.
Since failover would require identical configs and L3 connectivity, why not simply link them up and make a master-local setup out of 'em?
Not sure if it'll work with 2 standalone controllers or not, but doubt it to be honest. Haven't tested it though so someone might correct me.
Edit: see victor fabians link below
Please look at this article:
https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-we-configure-HA-AP-fast-fail-over-for-two-standalone/ta-p/253074
Thank you
Victor Fabian
Lead Mobility Architect @WEI
