AP not broadcasting SSID
  • 1.  AP not broadcasting SSID
    Posted Apr 24, 2018 02:07 PM
    I have an 225 series AP, controller based. It sits in an AP group along side many happy AP's, however this one fails to broadcast a specific SSID. Other than that it seems to be working fine.
    Can't figure why the AP group settings aren't taking affect. Any thoughts?
    I don't believe there's any config required, beyond simply assigning the AP group.
  • 2.  RE: AP not broadcasting SSID
    Posted Apr 24, 2018 02:10 PM
    Can you validate that the SSID/Virtual AP profiles are enabled ?
    Do you have a valid VLAN assigned that existing in the controller the AP is attached to?
  • 3.  RE: AP not broadcasting SSID
    Posted Apr 24, 2018 09:52 PM
    How have you validated that the AP is not broadcasting the SSID from the AP Group profile?
  • 4.  RE: AP not broadcasting SSID
    Posted Apr 25, 2018 01:00 PM
    Only validated in AirWave using the 'Active BSSID' info from the device info.
    I had a spare AP handy, dropped it into the same AP group and it's behaving properly. I hate not finding root cause but we're going with replacement as a solution for now.
