AP not connecting to master
Hey,
My AP is connecting to the VRRP of my MC but its unable to connect. I can see this in the datapath session. But it isn't showing up in the AP database.
I get following error.
ERRS> |cluster_mgr|  cmlb_ap_handle_ap_down_request, No entry in active table in LB-AP thread for AP with mac
Any idea?
Regular Contributor II
Re: AP not connecting to master
Hi
Maybe.a stupid question but is the AP in the whitelist? You are using CPSEC?
Cheers, Frank
Aruba Partner Ambassador| AMFX#22| ACCX#613| ACMX#733| ACDX#744
If you like my posts, kudo's are welcome. If it solves your problem, please click 'Accept as Solution'
Yes CPSec is enabled and I use Enable auto cert provisioning for CAP.
Does the access point show up under "show ap database"?
If this is ArubaOS 8.x, the AP should be pointing at one of the MDs, NOT the MMs.
no, the AP isn't showing up in the AP database.
The AP is pointing to the VRRP of the VMC-cluster
regards,
SSH into the VRRP and type "show log system 50" to see if you can get a clue what is wrong.
Jul 23 08:08:02  stm[5621]: <305006> <5621> <INFO> |stm|  AP 20:4c:03:23:79:b4 rebooted
Jul 23 08:08:38  cluster_mgr[5953]: <352302> <6391> <ERRS> |cluster_mgr|  cmlb_ap_handle_ap_down_request, No entry in active table in LB-AP thread for AP with mac 20:4c:03:23:79:b4
Jul 23 08:09:14  stm[5621]: <305006> <5621> <INFO> |stm|  AP 20:4c:03:23:79:b4 rebooted
Jul 23 08:10:19  cluster_mgr[5953]: <352302> <6391> <ERRS> |cluster_mgr|  cmlb_ap_handle_ap_down_request, No entry in active table in LB-AP thread for AP with mac 20:4c:03:23:79:b4
Jul 23 08:10:38  stm[5621]: <305006> <5621> <INFO> |stm|  AP 20:4c:03:23:79:b4 rebooted
Jul 23 08:11:39  cluster_mgr[5953]: <352302> <6391> <ERRS> |cluster_mgr|  cmlb_ap_handle_ap_down_request, No entry in active table in LB-AP thread for AP with mac 20:4c:03:23:79:b4
Jul 23 08:11:59  stm[5621]: <305006> <5621> <INFO> |stm|  AP 20:4c:03:23:79:b4 rebooted
Jul 23 08:12:59  cluster_mgr[5953]: <352302> <6391> <ERRS> |cluster_mgr|  cmlb_ap_handle_ap_down_request, No entry in active table in LB-AP thread for AP with mac 20:4c:03:23:79:b4
