AP not working when Mobility controller is rebooted
Hello every one,
I have a 3200 with some AP-105 (which are all running in bridge mode).
My problem is that when the AP(s) loose connection to the 3200 - they stop working after 30 sec (way less than the time it takes for the 3200 to reboot).
Is there a way to increase this timeour (or disable it) ?
Thank you.
Br
Jørgen
Re: AP not working when Mobility controller is rebooted
You need to convert that AP to a Remote AP, and then choose the Remote AP Mode in the Virtual AP to Permanent.
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Hi cjoseph,
Would that just be one of my AP's ?
I've just tried to provision it into a RAP but it seems to be staying down (at least from the Mobility controller view point).
Is the purpose of this to turn one of the AP's into a kind of a local controller ?
Thanks for the help
Jørgen
Hi cjoseph,
So. I tried to convert one of my AP's into a RAP unit. Seems to work just fine when the 3200 is reachable, BUT ....
If I reboot the 3200 (or lose connection to it from the RAP) - then it still stopps to process the traffic (however it does seems like it holds out a bit longer - seems to be somewhere around 90 sec).
Is there a way to increase this threshold so my wifi clients doesn get their traffic dropped if I reboot the 3200 ?
Br
Jørgen
A bit more jumping on this and it finally worked.
Kudos to cjoseph - now running RAP mode and continues to work even if controller is down
excellent!
