Frequent Contributor II
AP packet capture with wireshark
I have tried do some packet capture traffic from AP using wireshark 0.99.7 and 1.4.1 downloaded from the tools in the support area, using the ARUBA udp 5555 port, but I can't get anything, is there any requirement to do it?
Re: AP packet capture with wireshark
Please see the thread here:  http://community.arubanetworks.com/t5/ArubaOS-and-Controllers/How-do-we-do-packet-capturing-on-ArubaOS/m-p/1126/highlight/true#M149 for some ideas.
Yes, I have already read it, but following the indications I can't get any packet in wireshark.
I have AOS 5.0.3.0
Does the capture go from AP to PC directly or it goes throught controller?
AP to PC directly on port 5555
If I start wireshark capturing with my own NIC using a filter with source ip = ip of my Campus AP and then I start the AP packet capture, I don't see anything. It is correct?
Please read the document here:  http://community.arubanetworks.com/aruba/attachments/aruba/115/160/1/Packet+Capturing+Options+with+Aruba+Wireless+Networks.pdf
May be the problem is with winpcap, I use winpcap 4.1 and I don't know if it is supported with this version.
I use w7, so winpcap 3.1 is not supported with w7, please, could you confirm if wireshark-win32-aruba-1.4.1 only works with winpcap 3.1?
If you are streaming from an access point to a management station, I don't think Winpcap comes into play.  The management station just needs to receive traffic from the ip address of the AP on port 5555.
What are you trying to do, exactly?
As first test only streaming from ap to pc, but I can't see any traffic
