Regular Contributor I
AP's 92 Ethernet LED Solid Orange However they are serving Clients.
On AP 9 Ethernet LED is Solid Orange. Howerver they are serving clients. However Some other AP's have solid green . All AP;s are connected to the same POE switch.
Please assist,.
Valued Contributor I
Re: AP's 92 Ethernet LED Solid Orange However they are serving Clients.
Orange Eth LED = 10 /100Mbps
Green Eth LED = 1000Mbps
Are your switch ports set to Auto-Negotiate or is the one port hard-set to 100Mbps?  Cabling?
