Hi, I have IAP-315 AP's and I am trying to convert them to campus ap's pointing to our VMC which is managed by a virtual MM. It was working at one point, but not anymore...not sure what happened as we were troubleshooting other issues, and then all of the sudden this stopped working.
The AP's show on their own GUI that they convert successfully. They then reboot, but I don't ever see them in the list of AP's on the VMC. And teh AP's just continually reboot and I can no longer log into them unless I factory default them.
I've tried various 8.0 codes, 8.1, and 8.2...but still the same thing. Is there a command I can do on the VMC or MM to see if infact they AP's are connecting to the VMC? It's pulling an image, so I assume it has to be connecting to the VMC, but there is nothing in the AP database nor in the GUI of the MM showing the AP's exists.
Thanks for the help!
