Regular Contributor II
AP's showing down but they are up and running
I noticed that after we upgraded to 6.3.1.2 that 11 AP's are showing up on the Masteras down, but show they have clients connected to most of them. If I go to the local where they terminate they show up. Any ideas why this happened?
Re: AP's showing down but they are up and running
This is a known bug.
Sent from Windows Mail
Tim Cappalli | Aruba Security
Thanks for the quick reply. Has this been fixed in new versions of AOS?
I believe it is fixed in 6.4 but you might want to open a TAC case to get verification.
