AP ssid broadcast without network connectivy
  • 1.  AP ssid broadcast without network connectivy
    Posted Dec 13, 2013 03:13 PM
    HI,
    I have an AP on a stick survey that I need to complete with an IAP134. We have a group setup in our company controller that has the settings and VAP profile for broadcasting the SSID.
    The problem I am getting in the the specific AP configuration. The IAP134 will just sit there with a flashing power light and will not come up.
    Does anyone know why this AP wont come up? Unfortunetly the colleage that set our 105 up is in an airplane right now.
    This is the current printenv:
    apboot> print
    bootdelay=2
    baudrate=9600
    autoload=n
    boardname=Arran
    bootcmd=boot ap
    autostart=yes
    bootfile=armv5te.ari
    ethaddr=24:de:c6:c6:0f:18
    os_partition=0
    num_ipsec_retry=85
    name=Survey_134
    group=SiteSurveyRAP
    gatewayip=10.10.10.1
    netmask=255.255.255.0
    ipaddr=10.10.10.236
    ip6prefix=64
    dnsip=10.10.13.12
    domainname=our.domain
    servername=aruba-master
    a_ant_gain=398d218a36cb0ab19ff32af291b811c510787151200014x002
    g_ant_gain=398d218a36cb0ab19ff32af291b811c510787151200014x002
    ap70_ext_ant=1
    a_antenna=0
    g_antenna=0
    ikepsk=F07B34BA6B05A043A3DCD3B262B123783B0843B4CABACD295BC5A4E1E71D6F82
    pappasswd=2C257B8C3937B1A19A3E75169F8922DEFE6C9868ECED18A2
    usb_type=0
    uplink_vlan=0
    auto_prov_id=0
    is_rmp_enable=0
    remote_ap=1
    priority_ethernet=0
    priority_cellular=0
    cellular_nw_preference=1
    usb_power_mode=0
    mesh_role=0
    installation=0
    mesh_sae=0
    start_type=warm_start
    ethact=eth0
    master=10.255.192.2
    serverip=10.255.192.2
    papuser=RemoteAP
    stdin=serial
    stdout=serial
    stderr=serial
  • 2.  RE: AP ssid broadcast without network connectivy
    Posted Dec 13, 2013 04:59 PM
    You need to connect this IAP back into the network.  There is a setting once you get back in that allows the AP to come up without an ethernet connection.  I forget where that is...don't have access to an IAP right now.  I believe this is what's happening.
  • 3.  RE: AP ssid broadcast without network connectivy
    Posted Dec 13, 2013 08:50 PM
    If you want to set up an IAP for site survey this is how you do it
    http://community.arubanetworks.com/t5/Unified-Wired-Wireless-Access/Site-Survey-with-IAP-Manual/td-p/57274
    Cheers
    Carlos
