Contributor II
AP usb port disable on controller? (CAP 기반에서 AP의 USB포트 비활성화)
[ENG]
The customer wants to disable the USB port of AP running in Campus AP mode for security reasons.
Is it possible to set in the controller?
[Korean language]
고객은 CAP 모드로 운영중인 AP의 USB포트를 보안상의 이유로
컨트롤러에서 비활성화 하려고 합니다.
컨트롤러에서 설정이 가능한가요?
MVP
Re: AP usb port disable on controller? (CAP 기반에서 AP의 USB포트 비활성화)
What code version? V6, V8?
Sean Rynearson
Contributor II
version 6.5.3.3
The options available through the AP provisioning profile can be found here:
http://www.arubanetworks.com/techdocs/ArubaOS_6_5_3_X_Web_Help/Web_Help_Index.htm#ArubaFrameStyles/1CommandList/ap_network_profile.htm?Highlight=USB%20disable
For your case, generally disabling the USB port, you could set the usb-power-mode to disable to prevent connected devices from receiving power.
Charlie Clemmer
Aruba Customer Engineering
Contributor II
Thank you for your help.
