Hi
The customer uses AP93. They informed one day they were difficult to connect wireless network. They found out AP wave output was weak as a result of measuring NetStumbler. It was fixed after AP93 reboot. What can you think about the reason AP's wave output became weak suddenly?
3600
5.0.3.3
ARM enable
Best Regards
Simon
You need to be able to see what the transmit power of the AP is before it reboots, as a starting point, period.
Anything beyond that is spectulation.
