Regular Contributor I
AP won't License
I am having a problem adding an AP to a 3600 controller running software.
I connected a new AP to the network and it shows up on the controller with a IL flags (Inactive and unlicensed)
There are 24 unused licenses on the controller. (See screenshots)
I've tried a couple different new AP's but they all show up the same way.
Control plane security is off.
I've rebooted the controller as well.... no luck.
Any ideas????
Re: AP won't License
Can't tell from your limited screen shot if you have other feature licenses on the same controller.
For instance, do you have PEF/PEFNG and/or WIP/RFP licenses as well ?
If you do, are they quantity = 128 or quantity = 152 ?
(Master_Aruba3600-US) #show ap license-usage
Total AP Licenses                       : 152
Remote-Node AP Licenses Used            : 0
AP Licenses Used                        : 128
 Tunneled Node Licenses Used                     : 0
Unused AP Licenses                      : 24
Licenses used for Campus AP's           : 128
Available Campus AP's                   : 0
Licenses used for Remote AP's           : 0
Available Remote AP's                   : 0
Total Ortronics AP Licenses             : 0
Ortronics AP Licenses Used              : 0
Total Indoor Mesh AP's Supported        : 512
 Indoor Mesh AP's Active                 : 0
Total Outdoor Mesh AP's supported       : 512
Outdoor Mesh AP's Active                : 0
Total PEF Licenses                      : 152
Remote-Node PEF Licenses Used           : 0
PEF Licenses Used                       : 128
Total 802.11n-120abg Licenses   : 0
 802.11n-120abg Licenses Used    : 0
Total 802.11n-121abg Licenses   : 0
802.11n-121abg Licenses Used    : 0
Total 802.11n-124abg Licenses   : 0
802.11n-124abg Licenses Used    : 0
Total 802.11n-125abg Licenses   : 0
802.11n-125abg Licenses Used    : 0
A 3600 will only support 128 Campus APs.  Aruba allows more AP licenses because a 3600 can support up to 512 remote APs (RAPs).
If these are all in Campus AP (CAP) mode, you have hit the limit of the 3600.
Wow.... i should have known that. It must be a Friday.... time to go home I think.
Friday is good :)
WIth the full snapshot of the licensing output it can been seen that you have all APs in campus mode.
Notice the 'number of remote APs available: 0' output...   zero is zero ;)
