Frequent Contributor II
AP103 For Wall Mount
We have WIFI project  & Survey showed that we need some APs to be wall mounted
we want to use AP-103 to save cost & because areas are low density ... but found that inside AP103 datasheet it is written that  "  Built-in antennas are optimized for horizontal ceiling
mounted orientation of the AP."
Does this mean that AP103 is not good for wall mount  & using AP-103H is a must ?
Re: AP103 For Wall Mount
Correct. You can also use an L bracket to mount the 103 on the wall.
Tim Cappalli | Aruba Security
What is Correct  :D  ?
if AP103 can be mounted on wall ... will it be fine @ Coverage ?
You should make every attempt to mount it horizontally. You can use an L bracket to mount it horizontally on a wall.
What is this L Bracket ?
What is the part number
Home Depot or Lowes ;-)
