Contributor I
AP103 and Plenum Rating
Hi All
What can i do and cannot do when an AP is not Plenum Rated?
Can i still install it in the ceiling? is it just that i cannot place it between the false ceiling and hard ceiling?
Harry
Re: AP103 and Plenum Rating
You can't install it in a plenum space. You'd want to check with local building code. Not all drop ceilings require plenum.
Tim Cappalli | Aruba Security
Frequent Contributor II
Resurrecting older thread here. I understand the 103 isn't rated for plenum, but I guess I'm not entirely clear what that entails. Would this disqualify it from being used in a residential attic? For example, mounted to rafters?
Network Engineer | Airhead | Titus 3:5
Clayman,
Is there somewhere that you saw the Ap-103 is not rated for plenum?
Colin, yes. In the AP product line matrix it shows that the 103's are not plenum rated.
Please point me to the URL so that I can forward it to product marketing.
http://www.arubanetworks.com/pdf/products/MAT_AP.pdf
Is that inaccurate?
It has to be double-checked because the datasheet says it is plenum rated.  http://www.arubanetworks.com/assets/ds/DS_AP103Series.pdf
It is plenum rated.  The AP Matrix needs to be fixed.  Thanks for pointing that out.
