AP104 - LAN-LAN bridge with two cluster in standalone controller
Hi Experts, I have a standalone controller with two Mesh cluster profiles each cluster with pair of portal and point. Both the clusters connect to the same LAN. All works fine with both the Portals active. However when I test Redundancy by taking down of the Point/portal in any one cluster the failover of traffic through the other active mesh node is not working. Can we achieve cluster cluster redundancy? my Setup in similar to Figure 35 in the link below. Need your help badly on how to achieve redundancy here. http://www.arubanetworks.com/techdocs/ArubaOS_61/ROBOHELP%20UG%206.1/ArubaOS_User_Guide_-_volumes/Mesh.htm Thanks in advance. Shabeer
Re: AP104 - LAN-LAN bridge with two cluster in standalone controller
Are the settings the same in the mesh clusters?  If not, there is no chance that an AP in one cluster will connect to an access point in a different cluster....
Thanks for the feedback. I have difference settings. As I dont want the APs in one cluster to join the MPP in other cluster.
I would like to do an Cluster-cluster redundancy where if one ap in a cluster fails the traffic should go via the APs in the other cluster.
shadowsfx45 wrote:
Yes, but APs must have cluster settings in common for that to happen...
Hi
Cluster setting in the sense mssid ?? And so or the complete settings.
I will test it again tomorrow.
thanks for the help so far :)
When you Provision a Mesh Point or Mesh Portal, there is a mesh cluster profile that is attached to that access point.  If you provision two different access points with the same mesh cluster profile, they can mesh with each other.  If you provision them with two different mesh cluster profiles, they probably will not be able to connect unless the parameters in the two different cluster profiles match, like encryption, Mesh SSID and PSK.
Finally it worked.
Thanks a ton for the help :)
