Regular Contributor I
AP104 usage with two ANT-1b antenna
I have a AP104, i can use only two antennas of ANT-1b on it. one for 5Ghz and another for 2.4Ghz.
Which port i must use A0 or A1 for each R0 and R1 ?
what configuration tuning i must do..
Re: AP104 usage with two ANT-1b antenna
Here you go:
R0/A0: Radio 0 (5GHz), chain 0
R0/A1: Radio 0 (5GHz), chain 1
R1/A0: Radio 1 (2.4GHz), chain 0
R1/A1: Radio 1 (2.4GHz), chain 1
Seth R. Fiermonti
Consulting Systems Engineer - ACCX, ACDX, ACMX
Email: seth@hpe.com
If you found my post helpful, please give kudos
Thank you Seth,
I have two antennas only, one for each band. Which antenna port, i have to use for best signal coverage. A0 or A1?
This is not recommended. Either use the 2.4 or 5 radio only and shut off the one not in use. Or purchase two other antennas
Seth R. Fiermonti
Email: seth@hpe.com
@SethFiermonti So, there should be no antenna port that is left open, right.?
Yes - no port left open unless you disable that radio (in case you don't have 4 antennas)
Seth R. Fiermonti
Email: seth@hpe.com
