Occasional Contributor I
AP105 - Power adaptor
Does anyone know the spec for the power connector, i know 12v 2A
But what size is the power connection?
MVP
Re: AP105 - Power adaptor
If you are using AP-AC-UN ,u may find more detailed info in the following link:
http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Default.aspx?EntryId=9020
Hope it will answer you needs.
Have a lovely weekend.
Me.
Aruba
If you want to use a locally sourced alternative for the adapters Aruba offers (AP-AC-UN or AP-AC-12V18):
- 12V +/- 5%
- 15W or higher
- DC plug: 1.7/4.0mm center-positive circular plug with 9.5mm length
/Onno
