AP105- Speed stuck at 100Mbps.
hi,
We have a 3200 Controller and it is connected to 25 AP's .
Few AP transmitting at 100MBPS with a red flashing light and few at 1Gbps speed with green flashing light.
I tried changing the ports, changing the POE injector, using ports and injectors which deliver 10Gbps speed on the low speed AP.
I also upgraded the controller's OS version to the new 6.3.1, still the same.
Nothing worked with this AP transmitting at 100Mbps. What am I missing ?
Santhosh.
Re: AP105- Speed stuck at 100Mbps.
Are you able to test the cable with a tester? How about plugging in a
laptop?
Tim Cappalli | Aruba Security
Hi Tim,
How do you connect a Ap in a laptop?
I have used a cable from a Ap which is transmitting at 1Gbps.
Santhosh.
Ok, yes I meant use the cable feeding the AP on the laptop.
Does anything look out of the ordinary when you do a show interface status
on the switchport while the AP is plugged in?
