AP105 in bridge mode
  • 1.  AP105 in bridge mode
    Posted Jul 12, 2012 04:42 PM
    I have a set of APs on a 3600 controller that we are trying to get to bridge into our lan traffic.  When configured and provisioned the AP reboots and shows red on all indicators except power.  It shows as UP and provisioned but no SSID is being broadcast.
    Thoughts?
    #3600
  • 2.  RE: AP105 in bridge mode
    Posted Jul 12, 2012 07:05 PM
    Go to Configuration> Wireless> AP Installation.
    See if your AP has any flags..
  • 3.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 09:34 AM
    Has a flag of I
  • 4.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 11:12 AM
    I rebuilt the AP group and reprovisoned it.
    Now only the ENET light is red.
    When consoled into the AP i see:
    # vap aruba000 vlan is 0. discovering tunnel vlan
    ~ # vap aruba100 vlan is 0. discovering tunnel vlan
    Can it not find my controller?  I'm not sure what to make of it.
    Thank you,
  • 5.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 11:15 AM
    What is the virtual AP VLAN for that SSID?
  • 6.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 11:24 AM
    It has 2 SSIDs, one for Staff, which is bridged, and the other for Guest, which is tunnel.
    Guest SSID: has VLAN Pool VLAN_Guest
    VLAN GUEST has VLAN 3 so far included.
  • 7.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 11:26 AM
    You cannot do bridging for a VLAN pool.  Please put in a number, instead.
  • 8.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 11:34 AM
    The SSID that is bridged is not in a VLAN Pool, it is in a separate VLAN 2
  • 9.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 11:50 AM
    Correction VLAN1 not 2
  • 10.  RE: AP105 in bridge mode
    Posted Jul 13, 2012 01:12 PM
    It turns out I needed Control Plane Security Enabled and had to remove vlan from the Bridge SSID completely.
