Occasional Contributor I
AP125 Radio LED stays Amber
Problem: AP125 has the b/G and N Radio LEDs flashing Amber it could mean the following:
Amber: radio not configured for HT
If HT is configured, then check the 802.11 Security under the SSID Profile and check the Network Authentication Mixed Mode and you will get the Amber LEDs flashing if the security was set to dynamic-wep
Does anyone else or has anyone else had this problem?
Regular Contributor I
Re: AP125 Radio LED stays Amber
If they are flashing, the AP is setup as an Air Monitor (AM)
If a device is an AM on both or either band, the band light will be blinking no?
yes thats correct.
