Contributor I
AP125 and AP175 Installation Manuals
Does anyone have AP125 & AP175 installation manuals ? Previously it was available in the below link but now this document is not available.
https://www.arubanetworks.com/support, then click on Documentation > Hardware > AP Installation Guides > AP-120 Series > AP-120 Series Indoor Access Point Installation Guide.
Retired Employee
Re: AP125 and AP175 Installation Manuals
They are still available on the support site at the following locations:
Documentation -> Hardware Installation Guides -> APs -> AP-120 Series
Documentation -> Hardware Installation Guides -> APs -> AP 175
Hardik
HT
I believe you want http://support.arubanetworks.com
Then Documentation, Hardware Installation Guides, APs.
Zach Jennings
