AP134 and Power Injector
Hi All,
I have the following strange behavior regarding AP134.
If I connect them on POE switches (802.3af) they work without problems.
I have an error about the insufficien POE voltage on eth1 but I have read on the manuale that it's correct:
Shutting down eth1 due to insufficient POE voltage
If I use power injectors, AP134 power on (power led is green), but the eth0 port is not able to goes up:
Starting Kernel AESGCM KAT ...Completed Kernel AESGCM KAT
Domain Name: arubanetworks.com
No panic info available
init mv_cesa ok
Ethernet port 1 mode: active-staEthernet Channel Bonding Driver: v3.5.0 (November 4, 2008)
ndby
eth0: link down
ADDRCONF(NETDEV_UP): eth0: link is not ready
ADDRCONF(NETDEV_UP): bond0: link is not ready
eth0: link down
bonding: bond0: enslaving eth0 as a backup interface with a down link.
eth1: link down
bonding: bond0: enslaving eth1 as a backup interface with a down link.
AP xml model 50, num_radios 2 (jiffies 2496)
init_asap_mod: installation:0
radio 0: band 1 ant 1 max_ssid 16
radio 1: band 0 ant 1 max_ssid 16
ethernet_device_event: dev eth0 is up
Starting watchdog process...
Getting an IP address...
Time out
The ETH0 led is not power on.
If I connect on the same power injector an AP105, it works without problems....
Is it possible?
Someone can help me?
Gian
Re: AP134 and Power Injector
What is the model power injector?  The AP125 could draw more power than the AP105.
Thanks Cjoseph for your support.
The power injector is a common object (ARP product).
From the AP134 DS I read:
POWER
• 48 volts DC 802.3af power over Ethernet (PoE) or 802.3at PoE+
- Note: when using 802.3af POE, the second Ethernet port is disabled. It is enabled when using an 802.3at POE power source (or direct DC power).
I was hoping that 802.3af was enough.
Best Regards
Gian
gianti81,
I would try a different model of power injector and see if you achieve the same result, because they are not all created equal.  It does work with POE.
