Contributor II
AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
AP135 is plugged into Cisco 3560x switch and lldp is enabled as well. But it shuts down eth1 port due to insufficient power.
Any ideas?
Re: AP135 shuts down eth1 due to insufficient POE voltage [power profile 2]
You need 802.11at in order to get power on e1 and the 3560 supports 802.11af instead.
Thank you
Victor Fabian
Lead Mobility Architect @WEI
Aruba
What code are you running? This behavior has been changing a bit in recent releases.
Prior to 6.2, only layer 1 negotiation for 802.3at POE was supported. With 6.2, LLDP can be used to identify an 802.3at source.
/Onno Harms, Aruba
/Onno
Contributor II
@vfabian - 3560X supports POE+
The code is 6.1.3.8. This means I need to use a POE injector for the AP?
Aruba
If you need the second ethernet port, you should either use an 802.3at midspan, or upgrade to 6.2.
/Onno
missed the "x"
Thank you
Victor Fabian
Contributor II
I also had to upgrade the IOS image on Cisco 3560X to get it working. (12.2 => 15.0)
