AP205 won't provision
Hi All
First time poster, so be gentle please...
We've got an AP205 that just won't configure - it can't be seen on the controller (managed by a 3rd party IT provider) though other AP205s we have work without any problems.
I've copied the output from the putty session via the serial cable - can anybody see anything glaringly obvious? My gut instinct is that the flash memory has corrupted but I'd be grateful for any guidance.
Best wishes
Mike.
apboot> boot
bootcmd environment variable not found
apboot> purgeenv
Erasing flash...apboot> save
Saving Environment to Flash...
Erasing flash...apboot> boot
Checking image @ 0x1e100000
Invalid image format version: 0xea14f09f
Checking image @ 0x1ef00000
DHCP broadcast 1
DHCP IP address: 192.168.65.235
DHCP subnet mask: 255.255.255.248
DHCP def gateway: 192.168.65.233
DHCP DNS server: 0.0.0.0
DHCP DNS domain:
Controller address: 10.0.6.131
Using eth0 device
TFTP from server 10.0.6.131; our IP address is 192.168.65.235; sending through g        ateway 192.168.65.233
Filename 'armv7ns.ari'.
Load address: 0x4000000
Loading: #################################################################
done
Bytes transferred = 6506804 (634934 hex)
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
Automatic boot of image at addr 0x04000000 ...
Uncompressing... done
[    0.000000]
[    0.000000] Aruba Networks
[    0.000000] ArubaOS Version 6.4.2.5 (build 48774 / label #48774)
[    0.000000] Built by p4build@formentera.arubanetworks.com on 2015-02-24 at 20:35:48 PST (gcc version 4.7.2)
[    0.000000]
[    0.000000] Flash variant: variant0
[    0.000000] Memory: 128MB = 128MB total
[    0.000000] Memory: 121124k/121124k available, 9948k reserved, 0K highmem
[    0.052000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[    3.266000] PMU: registered new PMU device of type 0
[    3.772000] pci 0001:00:00.0: BAR 8: assigned [mem 0x08000000-0x080fffff]
[    3.774000] pci 0001:01:00.0: BAR 0: assigned [mem 0x08000000-0x08007fff 64bit]
[    3.776000] pci 0001:01:00.0: BAR 0: set to [mem 0x08000000-0x08007fff 64bit] (PCI address [0x8000000-0x8007fff]
[    4.278000] pci 0002:00:00.0: BAR 8: assigned [mem 0x40000000-0x400fffff]
[    4.280000] pci 0002:02:00.0: BAR 0: assigned [mem 0x40000000-0x40007fff 64bit]
[    4.282000] pci 0002:02:00.0: BAR 0: set to [mem 0x40000000-0x40007fff 64bit] (PCI address [0x40000000-0x40007fff]
[    4.628000] i2c-springbank: using remapped base c9d1c060
[    4.630000] mpcore_wdt mpcore_wdt: enabling watchdog.
[    4.634000] qspi_iproc qspi_iproc.1: 1-lane output, 3-byte address
[    4.638000] m25p80 spi1.0: mx25l25635e (32768 Kbytes)
[    4.640000] Creating 1 MTD partitions on "spi1.0":
[    4.642000] 0x000000000000-0x000002000000 : "qspi"
[    4.646000]
[    4.646000] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
[    4.650000] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
[    4.664000] Starting Kernel DES KAT ...Completed Kernel DES KAT
[    4.668000] Starting Kernel AES KAT ...Completed Kernel AES KAT
[    4.670000]
Domain Name: arubanetworks.com
cat: /tmp/boardname: No such file or directory
[: Ardmore: unknown operand
No panic info available
[: Talisker: unknown operand
[    6.326000] AP xml model 81, num_radios 2 (jiffies 3163)
[    6.328000] init_asap_mod: installation:0
[    6.330000] radio 0: band 1 ant 0 max_ssid 16
[    6.332000] radio 1: band 0 ant 0 max_ssid 16
Starting watchdog process...
Getting an IP address...
[    8.724000] ADDRCONF(NETDEV_UP): bond0: link is not ready
[   10.726000] bond0: link up (1000FD)
[   10.730000] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
192.168.65.235 255.255.255.248 192.168.65.233
Running ADP...Done. Master is 10.0.6.131
[   13.356000] wifi0: AP type AP-205, radio 0, max_bssids 16
[   13.400000] wifi1: AP type AP-205, radio 1, max_bssids 16
[: closing paren expected
AP rebooted Fri Nov 4 14:32:44 GMT 2016; SAPD: Reboot after image upgrade failed: 256
shutting down watchdog process (nanny will restart it)...
        <<<<<       Welcome to the Access Point     >>>>>
The system is going down NOW !!
Sending SIGTERM to all processes.
Please stand by while rebooting the system.
[   59.488000] Restarting system.
APBoot 1.5.3.14 (build 45815)
Built: 2014-09-05 at 11:23:04
Model: AP-20x
CPU:   BCM53011/15, revision A0
I2C:   ready
SKU:   2
OTP:   0xeca01028
Clock:
       CPU:  800 MHz
       DDR:  533 MHz
       AXI:  400 MHz
       APB:  200 MHz
       PER:  400 MHz
DRAM:  128 MB
POST1: memory passed
SF:    Detected MX25L25635E with page size  4 kB, total 32 MB
Flash: 32 MB
PCIe0: RC, link up
       dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
       00  00  14e4  4360 00002   03 08000004 00000000 00000000 00000000
PCIe1: RC, link up
       00  00  14e4  4360 00002   03 40000004 00000000 00000000 00000000
Power: DC
## Error: environment overflow, "stdin" deleted
## Error: environment overflow, "stdout" deleted
## Error: environment overflow, "stderr" deleted
Net:   ERROR: could not get env ethaddr
## Error: environment overflow, "ethact" deleted
eth0## Error: environment overflow, "ethact" deleted
Radio: bcm43460#0, bcm43460#1
apboot> Printenv
Re: AP205 won't provision
You should open a tac case.  It could be a hardware issue...
ArubaOS 8.3 User Guide
InstantOS 8.3 User Guide
Airheads Knowledgebase
Frequent Contributor II
I agree with CJ, Several years ago I had a very similar issues with two AP105's. Turns out there was bad hardware involved and TAC set me up with warranty replacements.
Scott McNeil - Sr. Network & Security Engineer, Global Process Automation
Network+ | CWNA | CWTS | ACSP | ACMP | ACMA | BREC
