AP214 with AP-ANT-16 antenna
Hello Guys
Im quoting this but im not sure if i just need one antenna
I bealive i just need one as the antenna i think it comes with the 3 cables to connect to the 3 holes in the 214 AP
But im not 100% sure of that... i rarely quote APs with external antennas.
My question is simpleAP-ANT-16? or i need 3 AP-ANT-16
Also do i need any additional thing?
Cheers
Carlos
Alternetworks Corp
Re: AP214 with AP-ANT-16 antenna
Hi Carlos,
The ANT-16 comes with 3 fly cables and three RPSMA connectors so it will connect up to the AP-214 (make sure you configure it with the correct gain settings though).
Also, make sure this is the correct antenna you need. For example, we use it to hide the AP above the ceiling with just the antenna visible below.
Best wishes
Alexander.
University Information Services
University of Cambridge
Thank you very much alexander!
Cheers
Carlos
Alternetworks Corp
