AP215
I upgraded my 7240 comtrollers to 6.4.2.2 and I upgraded Airwave to 8.0.5 for the AP 215. The controllers see the AP215 but airwave will not discover the AP 215. What am I missing?
Re: AP215
Are all of your controllers in AirWave?
Tim Cappalli | Aruba Security
Aruba
Re: AP215
If the AP-215 is up on the controller and AirWave is monitoring that controller, AirWave should detect it on the next polling interval; and place it under the New Devices section.     Have you tried to manually poll your controller to force it to show?
ACCX | ACDX | ACMX
Re: AP215
Yes
Re: AP215
The controllers still detect new AP 135 that are connected
Aruba
Re: AP215
AirWave 8.0.4 supports the AP-214/215.  If the AP is up on the controller and the controller is monitored (and successfully polling), then it should appear within AirWave during the next or force poll.
  • Is this a new AP-215; or was it online prior to your upgrade to AirWave 8.0.5?
  • Do you have another AP-215 to try?
  • Can you check the System Event Log in AMP and the Poll logs for that controller to see if there are any polling messages?
  • Can you confirm that you don't have any "new devices" set to "ignore"?   Click View Ignored Devices under New Devices.
ACCX | ACDX | ACMX
Re: AP215
I did a manual poll of the controllers and it found the 2 AP 215s that were connected.  So I plugged in another AP 215 and it auto discovered it.  So I'm not sure the cause but it appears to be working again.
Thanks for your help
