AP225 aggregated ports - configuration required?
I have a number of AP225 APs being installed without a controller.
I have LACP trunk ports setup on HP 2950 POE+ switches however once I connect both Ethernet ports on the AP I lose IP connectivity - I am unable to see where I apply any configuration to configure aggregated ports on the AP for throughput.
From what I have read I need to add a LMS IP and GRE STRIPING however this seems to be directed towards a controller?
Can someone advise?
Re: AP225 aggregated ports - configuration required?
Did you create a trunk on the switch with LACP enabled?
Tim Cappalli | Aruba Security
Yes - LACP trunk created on the switch
