Frequent Contributor I
AP225 not receiving power
Dear,
We have AP225s that are connected with both ports on an Alcatel OS6450-P24 switch. When we plug in the AP port by port, there is no problem, the AP is getting power and booting fine.
When the switch needs to reboot (due to an upgrade of the switch for example) the AP is not getting any power afterwards.
When we disconnect 1 of the 2 ports, the switch is getting power on the other port which is still connected and boots fine again, after it gets his power on that port, we can connect the other port again.
So it seems the switch does not know on which of the 2 ports he need to deliver power.
I tried the same on an Alcatel OS6850-P24X and I have the same issue.
Any idea? Somebody who has the same issue?
Kind regards,
Thomas
ACMX#370 ACCP
Re: AP225 not receiving power
what IAP version are you using?
Have you spoken to Alcatel?
Pasquale Monardo | Senior Network Solutions Consultant
ACDX #420 | ACCA
[If you found my post helpful, please give kudos!]
It is an AP, not an IAP.
But it is version  Version 6.3.1.0 (39345) (not yet configured, since it is in my lab without a controller for the moment)
For the moment I didn't opened a ticket with Alcatel yet, I want to be sure it is indeed an Alcatel issue or an Aruba AP issue, since I noticed it on 2 diferent types of Alcatel switches with same behaviour.
Do you have this type of APs in your lab? Can you test if you have the same behaviour on an other type of switch (I only have Alcatel) (so enable lanpower/POE on the 2 ports at the same time)
Thomas
ACMX#370 ACCP
sorry, misread your post, unfortunately I only have IAP-225s (which I can convert).
I would have to dig around to see if I have a POE+ switch around our lab...it is a complete mess right now due to flooding so equipment is everywhere.
ACDX #420 | ACCA
No Problem, in mean time I opened a ticket with Alcatel, since they have the same APs in their portfolio (OAW-AP225)  I hope they can investigate if it is switch or AP related
Thomas
ACMX#370 ACCP
Super Contributor I
This was an issue with the second port coming up before the first. If eth1 comes up before eth0 the AP will not come up. I know there have been some improvements in this in the newer versions of code, however I have a customer on Alcatel who changed a config to allow the first port to receive priority for power over the second. Not sure exactly what the config was, but you might want to look into that as well.
ACDX #419 | ACMP |
Aruba
This is a known issue with the AP-225 hardware.
The AP has a single controller for POE-PD, negotiating POE power on either one of the Ethernet ports (but not both simultaneously). When both ports are connected to a POE source, it can be hard to predict which one will be elected. When both POE sources are part of the same switch and POE is enabled simultaneously, there's a potential for a conflict which can lead to the switch disabling both ports.
/Onno Harms, Aruba
/Onno
I tried changing the POE priority on the Alcatel side, but not solving the issue; thanks for the tip though.
Thomas
ACMX#370 ACCP
/Onno Harms, Aruba
I opened a ticket with Alcatel, since they sell this same type of APs, they maybe already have a solution for this. I hope I receive a satisfying answer soon.
Thomas
ACMX#370 ACCP
