Contributor II
AP274 AP Boot Command Problem
I am having problems accessing AP boot commands on an AP274 from within the console. Please see the below console output.
APBoot 1.5.3.14 (build 46206)
Built: 2014-09-26 at 18:50:05
Model: AP-27x
CPU0:  P1020E, Version: 1.1, (0x80ec0011)
Core:  E500, Version: 5.1, (0x80212051)
Clock:
       CPU0: 800 MHz
       CPU1: 800 MHz
       CCB:  400 MHz
       DDR:  333.333 MHz (666.667 MT/s data rate) (Asynchronous)
       LBC:   25 MHz
L1:    D-cache 32KB enabled
       I-cache 32KB enabled
I2C:   ready
DRAM:  Configuring DDR for 666.667 MT/s data rate
DDR:   512 MB (DDR3, 32-bit, CL=5, ECC off)
POST1: memory passed
Flash: 32 MB
L2:    256 KB enabled
Power: 802.3at POE
PCIe1: RC, link up, x1
       dev fn venID devID class  rev    MBAR0    MBAR1    MBAR2    MBAR3
       00  00  14e4  4360 00002   03 80000004 00000000 00000000 00000000
PCIe2: RC, link up, x1
       00  00  14e4  4360 00002   03 a0000004 00000000 00000000 00000000
Net:   eth0, eth1
Radio: bcm43460#0, bcm43460#1
Hit <Enter> to stop autoboot:  0
apboot>
Unknown command '' - try 'help'
apboot> help
Unknown command 'help' - try 'help'
apboot> ?
Unknown command '?' - try 'help'
apboot> printenv
Unknown command 'printenv' - try 'help'
apboot> version
Unknown command 'version' - try 'help'
apboot> mfginfo
Unknown command 'mfginfo' - try 'help'
apboot>
AP has just come out of the box with only a power injector providing PoE, it is not currently connected to a switch.
Any ideas on this please? I'd expect these commands to work.
Cheers
Shaun
Re: AP274 AP Boot Command Problem
What are you trying to do? You already have a controller online? The AP is getting DHCP and has a way to discover the controller?
Jerrod Howard
Contributor II
Hi Jerrod,
Thanks for the quick reply - I want to give it a static IP address and Master controller IP address.
But that's not the point, a simple 'printenv' is not giving the AP config - Why??
Many thanks,
Shaun
when you issue a 'factory reset' (or 'factory default', I can't remember), as well as a 'clear os' what is the output? May have to reach out to TAC...
Jerrod Howard
Contributor II
Hi Jerrod,
Please see the below,
Model: AP-27x
Clock:
       CPU0: 800 MHz
       CPU1: 800 MHz
       CCB:  400 MHz
       LBC:   25 MHz
I2C:   ready
Flash: 32 MB
L2:    256 KB enabled
Power: 802.3at POE
Net:   eth0, eth1
Checking image @ 0xee000000
Invalid image format version: 0xffffffff
Checking image @ 0xeee00000
Copying image from 0xeee00000
Image is signed; verifying checksum... passed
Signer Cert OK
Policy Cert OK
RSA signature verified.
[    0.000000] Flash variant: default
[    0.000000]
[    0.000000] Aruba Networks
[    0.000000] ArubaOS Version 6.4.3.0 (build 47188 / label #47188)
[    0.000000] Built by p4build@cyprus on 2014-11-17 at 19:02:06 PST (gcc version 4.5.1)
[    0.000000]
[    0.000000] Memory: 509628k/524288k available (9092k kernel code, 14660k reserved, 508k data, 360k bss, 5652k init)
[    0.002932] Processor 1 found.
[    0.156850] Brought up 2 CPUs
[    0.233349] PCI: Probing PCI hardware
[    0.276395] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    0.339392] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
[    0.401621] pci 0000:00:00.0: enabling device (0106 -> 0107)
[    0.468813] pci 0001:02:00.0: enabling device (0106 -> 0107)
Model: AP-27x
Clock:
       CPU0: 800 MHz
       CPU1: 800 MHz
       CCB:  400 MHz
       LBC:   25 MHz
I2C:   ready
Flash: 32 MB
L2:    256 KB enabled
Power: 802.3at POE
Net:   eth0, eth1
apboot> factory_default
Unknown command 'factory_default' - try 'help'
apboot> clearos
Unknown command 'clearos' - try 'help'
apboot>
Exactly the same unfortuantley - Have you seen this before? I'll get in touch with TAC.
Many thanks,
Shaun
Contributor II
I have another AP 274 unboxed - I am using them for a Mesh. The same is happening on the second one too.
What are the chances of this happening to two different AP 274s? Or am I being a numpty and it needs to talk to a controller first before those commands become active?
trying printenv should display regardless of if it's new or not. 'clear os' (with the space) should wipe the current OS. I can't remember if it's factory_default, factory reset, etc (you should be able to do factory ?).
That it's both seems odd and very unlikely...am wondering if it's the serial connection not sending the right strings like it should. You have the driver from the support site, through a regular USB port and cable? What is the computer, host os, and software used?
The list of all ap env commands are pasted below
General Variables:
setenv ipaddr x.x.x.x
setenv netmask x.x.x.x
setenv gatewayip x.x.x.x
setenv master x.x.x.x
setenv serverip x.x.x.x
setenv location b.f.l
setenv group xxxxxx
setenv name xxxxx
Required without DNS or option 43:
setenv master
setenv serverip
Required without DHCP:
setenv ipaddr
setenv netmask
setenv gatewayip
Optional:
setenv dnsip
setenv group xxxxxx
printenv
setenv
save
purge
reset
ping
boot
version
clear os
upgrade
tftpboot
dhcp
Jerrod Howard
Contributor II
Ok fixed it - Very simple too :)
My Surface needed a restart after installing the USB driver - All is now Ok after the restart and I can see all AP boot commands.
Thanks for your help Jerrod in isolating this.
Many thanks,
Shaun
MVP
This is strange. I have an AP 274 doing the same thing. Not accepting AP-Boot parameters. Its only this AP 274 that I am having a problem with. I tried rebooting after installing the driver, no fix
Every command I type it says:
"Unknown Command" lol
Sean Rynearson
Contributor II
Hi Sean,
I found that using the driver on Windows 10 was very hit and miss. In the end I installed the driver on a Windows 7 PC and it worked 100% of the time.
Cheers
Shaun
