Contributor II
AP314 external antenna selection
Hi guys,
one of my customers bought some brand new AP 314. He need to install them above a ceiling tile which makes external antennas necessary.
The AP 314 has 4x RPSMA connectors and in the newest antenna matrix on the Arubanetworks page is only one antenna with 4 connectors.
we are looking for one antenna per AP which has more or less the sam pattern as an AP 315 (omni, downtilt)
thanks in advance
Frederik
Network Engineer
ACCX | ACMP
Re: AP314 external antenna selection
How high is the ceiling?
Contributor II
it differs. the average hight is 4.5m
Network Engineer
ACCX | ACMP
Contributor II
I think I found one we can use. It's the ANT40.
Thanks for your help!
Network Engineer
ACCX | ACMP
