Contributor II
AP315 disable radio 2.4
Hi, Guys,
We have an AP315 in a Controller environment running ArubaOS
We cannot enable 2.4Ghz radio on this AP. If I let "Allowed band" to "all" on VAP, only 5Ghz radio works. If I change it to "g", the AP flag to "I" (Inactive).
We have AP205 working fine in both radios in the same Controller.
Is it a software issue? Anyone have any tips?
Paulo R.
Re: AP315 disable radio 2.4
For the sake of completeness, can you capture a 'show ap tech-support' from that AP and attach it to a reply? When you do a 'show ap active' waht do you see for that AP?
Jerrod Howard
Contributor II
I found the issue... The 2.4Ghz radio was disabled on RF Management..
Thank you.
