AP325 and AP105 Configuration
We are using controller base solution.  85% of the wifi coverage is using AP105.  We recently purchased AP320 Series (325 and 324).  What is the best way to configure AP320 so that it won't interfere with AP105?  Can we still use the same ESSID with 2 different profiles (AP Group, VAP, ARM, SSID)?
Re: AP325 and AP105 Configuration
You should disable VHT on the 320s if they are coexisting in an 11n environment.
Tim Cappalli | Aruba Security
