Moderator
AP65 reset to default (no SoE)
Hi
I have an AP65 which seems to be stuck with some config that doesn't allow me to get it back to the controller. As far as I know I can only purge this AP via SoE. Is there any other way? Can I "rescue" this AP without purging it?
Thanks a lot
Samuel Pérez
ACMP, ACCP, ACDX#100
If I answerd your question, please click on "Accept as Solution".
If you find this post useful, give me kudos for it ;)
Re: AP65 reset to default (no SoE)
You can type "show audit-trail" on the controller and see how you configured that AP to get an idea of the the ip addressing information or the master controller ip address had a mistake.  You can then change the controller to match what you changed so that the AP can re-join the controller.  You can only wipe the config of an AP65 that cannot contact a controller using SOE or using the y-Cable.
Community Manager
Moving topic to Aruba APs board.
