Regular Contributor I
AP65 supported on 5x and 6x code?
We are in the process of upgrading controllers from 3.x to 6.x code.  We know that the AP61 and AP70 is supported.  We have a site that has AP65s and I'm assuming that they are supported as well in the newest code.  Just want to verify before we go head with upgrading those sites.
Thanks.
Re: AP65 supported on 5x and 6x code?
Yes, they are.  Just make sure you go from 3.x to 5.04.x then to 6.x.
Will do, thanks.
