AP70s do not register to Controller 800! Help!!
Does anyone here use Aruba 800 wireless controllers and AP70 on
their network ?   I am setting up this new wireless network with the
above equipment.  The wireless controllers are up on the network and
I can ping them, HTTPS to them however i can not get the APs to
register to the controller.
1) When i plug the APs to the switch they are getting an IP address
and I can ping them however it seems like they're going up down (
switchports are going from amber to green).   Do I need some kind of
special cable for the APs?  I went to configuration manual and follow
every step for the AP configuration and they are still not showing in
controller.
2) How do i provision the APs to communicate with the controller ?
controller config :
show run
Building Configuration...
version 2.4
enable secret "aa7891c511763a0428a019803059aeef65df5a3d3be23cc1"
enable "8L8E8N0T0Z0F8N5[5[8N"
hostname "aruba-master"
logging level warnings stm
clock summer-time UTC-5 recurring first sunday april 02:00 last sunday
october 02:00
clock timezone UTC -5
ip access-list session validuser
  any any any permit
vpn-dialer default-dialer
  ike authentication PRE-SHARE 218d0f532708d2c0a9963544c5733235dd78c9b696abed06
user-role ap-role
user-role pre-employee
user-role trusted-ap
user-role guest
--More-- (q) quit (u) pageup (/) search (n) repeat
user-role stateful-dot1x
user-role logon
aaa derivation-rules user
  set role condition essid equals "aruba-master" set-value pre-employee
aaa mgmt-authentication mode enable
aaa pubcookie-authentication
aaa dot1x enforce-machine-authentication
 mode disable
dot1x timeout wpa-key-timeout 1
interface mgmt
        shutdown
interface loopback
        ip address X.X.X.X
vlan 6
interface fastethernet 1/0
        description "fe1/0"
        trusted
        switchport access vlan 6
interface fastethernet 1/1
        description "fe1/1"
        trusted
interface fastethernet 1/2
        description "fe1/2"
        trusted
interface fastethernet 1/3
        description "fe1/3"
        trusted
interface fastethernet 1/4
        description "fe1/4"
        trusted
interface fastethernet 1/5
        description "fe1/5"
        trusted
interface fastethernet 1/6
        description "fe1/6"
        trusted
interface fastethernet 1/7
        description "fe1/7"
        trusted
interface gigabitethernet  1/8
        description "gig1/8"
        trusted
        switchport mode trunk
interface vlan 1
interface vlan 6
        ip address X.X.X.X X.X.X.X
ip default-gateway X.X.X.X
country US
ap location 0.0.0
ap-logging level informational snmpd
double-encrypt disable
ap-logging level informational sapd
ap-logging level warnings am
ap-logging level warnings stm
max-imalive-retries 10
bkplms-ip 0.0.0.0
opmode opensystem
mode ap_mode
authalgo opensystem
rts-threshhold 2333
tx-power 2
max-retries 4
dtim-period 1
max-clients 64
beacon-period 100
power-mgmt enable
ageout 1000
hide-ssid disable
deny-bcast disable
rf-band g
bootstrap-threshold 7
local-probe-response enable
max-tx-fail 0
forward-mode tunnel
native-vlan-id 1
arm assignment disable
arm client-aware enable
arm scanning disable
arm scan-time 110
arm scan-interval 10
arm multi-band-scan disable
arm voip-aware-scan enable
arm max-tx-power 4
arm rogue-ap-aware disable
voip call-admission-control disable
voip drop-sip-invite-for-cac disable
voip active-load-balancing disable
voip vocera-call-capacity 10
voip sip-call-capacity 10
voip svp-call-capacity 10
voip sccp-call-capacity 10
voip call-handoff-reservation 20
voip high-capacity-threshold 20
essid "XXX_Wireless"
vlan-id 6
weptxkey 1
ap-enable enable
  phy-type a
    channel 36
    rates 6,12,24
    txrates 6,9,12,18,24,36,48,54
    essid "aruba-master"
    vlan-id 6
    opmode opensystem
    deny-bcast enable
    hide-ssid disable
  phy-type g
    short-preamble enable
    channel 1
    rates 1,2
    txrates 1,2,5,11,6,9,12,18,24,36,48,54
    bg-mode mixed
    dtim-period 3
ap location 0.0.0
  phy-type enet1
    mode active-standby
    switchport mode access
    switchport access vlan 1
    switchport trunk native vlan 1
    switchport trunk allowed vlan ALL
    trusted disable
wms
 general poll-interval 60000
 general poll-retries 2
 general ap-ageout-interval 30
 general sta-ageout-interval 30
 general ap-inactivity-timeout 5
 general sta-inactivity-timeout 60
 general grace-time 2000
 general laser-beam enable
 general laser-beam-debug disable
 general wired-laser-beam disable
 general stat-update enable
 general am-stats-update-interval 0
 ap-policy learn-ap enable
 ap-policy classification disable
 ap-policy protect-unsecure-ap enable
 ap-policy detect-misconfigured-ap disable
 ap-policy protect-misconfigured-ap disable
 ap-policy protect-mt-channel-split disable
 ap-policy protect-mt-ssid disable
 ap-policy detect-ap-impersonation disable
 ap-policy protect-ap-impersonation disable
 ap-policy beacon-diff-threshold 50
 ap-policy beacon-inc-wait-time 3
 ap-policy min-pot-ap-beacon-rate 25
 ap-policy min-pot-ap-monitor-time 2
 ap-policy protect-ibss disable
 ap-policy ap-load-balancing disable
 ap-policy ap-lb-max-retries 8
 ap-policy ap-lb-util-high-wm 90
 ap-policy ap-lb-util-low-wm 80
 ap-policy ap-lb-util-wait-time 30
 ap-policy ap-lb-user-high-wm 255
 ap-policy ap-lb-user-low-wm 230
 ap-policy persistent-known-interfering disable
 ap-config short-preamble disable
 ap-config privacy disable
 ap-config wpa disable
 station-policy protect-valid-sta disable
 station-policy handoff-assist disable
 station-policy rssi-falloff-wait-time 4
 station-policy low-rssi-threshold 20
 station-policy rssi-check-frequency 3
 station-policy detect-association-failure disable
 global-policy detect-bad-wep disable
 global-policy detect-interference disable
 global-policy interference-inc-threshold 100
 global-policy interference-inc-timeout 30
 global-policy interference-wait-time 30
 event-threshold fer-high-wm 0
 event-threshold fer-low-wm 0
 event-threshold frr-high-wm 16
 event-threshold frr-low-wm 8
 event-threshold flsr-high-wm 16
 event-threshold flsr-low-wm 8
 event-threshold fnur-high-wm 0
 event-threshold fnur-low-wm 0
 event-threshold frer-high-wm 16
 event-threshold frer-low-wm 8
 event-threshold ffr-high-wm 16
 event-threshold ffr-low-wm 8
 event-threshold bwr-high-wm 0
 event-threshold bwr-low-wm 0
 valid-11b-channel 1 mode enable
 valid-11b-channel 6 mode enable
 valid-11b-channel 11 mode enable
 valid-11a-channel 36 mode enable
 valid-11a-channel 40 mode enable
 valid-11a-channel 44 mode enable
 valid-11a-channel 48 mode enable
 valid-11a-channel 149 mode enable
 valid-11a-channel 153 mode enable
 valid-11a-channel 157 mode enable
 valid-11a-channel 161 mode enable
 valid-11a-channel 165 mode enable
 ids-policy signature-check disable
 ids-policy rate-check disable
 ids-policy dsta-check disable
 ids-policy sequence-check disable
 ids-policy mac-oui-check disable
 ids-policy eap-check disable
 ids-policy ap-flood-check disable
 ids-policy adhoc-check disable
 ids-policy wbridge-check disable
 ids-policy sequence-diff 300
 ids-policy sequence-time-tolerance 300
 ids-policy sequence-quiet-time 900
 ids-policy eap-rate-threshold 10
 ids-policy eap-rate-time-interval 60
 ids-policy eap-rate-quiet-time 900
 ids-policy ap-flood-threshold 50
 ids-policy ap-flood-inc-time 3
 ids-policy ap-flood-quiet-time 900
 ids-policy signature-quiet-time 900
 ids-policy dsta-quiet-time 900
 ids-policy adhoc-quiet-time 900
 ids-policy wbridge-quiet-time 900
 ids-policy mac-oui-quiet-time 900
 ids-policy rate-frame-type-param assoc channel-threshold 30
 ids-policy rate-frame-type-param assoc channel-inc-time 3
 ids-policy rate-frame-type-param assoc channel-quiet-time 900
 ids-policy rate-frame-type-param assoc node-threshold 30
 ids-policy rate-frame-type-param assoc node-time-interval 60
 ids-policy rate-frame-type-param assoc node-quiet-time 900
 ids-policy rate-frame-type-param disassoc channel-threshold 30
 ids-policy rate-frame-type-param disassoc channel-inc-time 3
 ids-policy rate-frame-type-param disassoc channel-quiet-time 900
 ids-policy rate-frame-type-param disassoc node-threshold 30
 ids-policy rate-frame-type-param disassoc node-time-interval 60
 ids-policy rate-frame-type-param disassoc node-quiet-time 900
 ids-policy rate-frame-type-param deauth channel-threshold 30
 ids-policy rate-frame-type-param deauth channel-inc-time 3
 ids-policy rate-frame-type-param deauth channel-quiet-time 900
 ids-policy rate-frame-type-param deauth node-threshold 20
 ids-policy rate-frame-type-param deauth node-time-interval 60
 ids-policy rate-frame-type-param deauth node-quiet-time 900
 ids-policy rate-frame-type-param probe-request channel-threshold 200
 ids-policy rate-frame-type-param probe-request channel-inc-time 3
 ids-policy rate-frame-type-param probe-request channel-quiet-time 900
 ids-policy rate-frame-type-param probe-request node-threshold 200
 ids-policy rate-frame-type-param probe-request node-time-interval 15
 ids-policy rate-frame-type-param probe-request node-quiet-time 900
 ids-policy rate-frame-type-param probe-response channel-threshold 200
 ids-policy rate-frame-type-param probe-response channel-inc-time 3
 ids-policy rate-frame-type-param probe-response channel-quiet-time 900
 ids-policy rate-frame-type-param probe-response node-threshold 150
 ids-policy rate-frame-type-param probe-response node-time-interval 15
 ids-policy rate-frame-type-param probe-response node-quiet-time 900
 ids-policy rate-frame-type-param auth channel-threshold 30
 ids-policy rate-frame-type-param auth channel-inc-time 3
 ids-policy rate-frame-type-param auth channel-quiet-time 900
 ids-policy rate-frame-type-param auth node-threshold 30
 ids-policy rate-frame-type-param auth node-time-interval 60
 ids-policy rate-frame-type-param auth node-quiet-time 900
 ids-signature "ASLEAP"
   mode enable
   frame-type beacon ssid asleap
 ids-signature "Null-Probe-Response"
   mode enable
   frame-type probe-response ssid-length 0
 ids-signature "AirJack"
   mode enable
   frame-type beacon ssid AirJack
 ids-signature "NetStumbler Generic"
   mode enable
   payload 0x00601d 3
   payload 0x0001 6
 ids-signature "NetStumbler Version 3.3.0x"
   mode enable
   payload 0x00601d 3
   payload 0x000102 12
 ids-signature "Deauth-Broadcast"
   mode enable
   frame-type deauth
   dst-mac ff:ff:ff:ff:ff:ff
site-survey calibration-max-packets 256
site-survey calibration-transmit-rate 500
site-survey rra-max-compute-time 600000
site-survey max-ha-neighbors 3
site-survey neighbor-tx-power-bump 2
site-survey ha-compute-time 0
arm min-scan-time 8
arm ideal-coverage-index 5
arm acceptable-coverage-index 2
arm wait-time 15
arm free-channel-index 25
arm backoff-time 240
arm error-rate-threshold 0
arm error-rate-wait-time 30
arm noise-threshold 0
arm noise-wait-time 120
ems server-ip 0.0.0.0
crypto isakmp groupname changeme
vpdn group l2tp
  ppp authentication PAP
masterip 127.0.0.1
location "Building1.floor1"
mobility
  parameters 60 buffer 32
  manager disable
  proxy-dhcp enable
  station-masquerade enable
  on-association disable
  trusted-roam disable
  ignore-l2-broadcast disable
  block-dhcp-release disable
  no new-user-roaming
  max-dhcp-requests 4
  secure 1000 shared-secret 4012c7accbe0f26bbb1703b4bf36dfa0
mobility-local
  local-ha disable
mobagent
  home-agent parameters 1000 bindings 300
  secure-mobile spi 1000 3abd01a8027810fb5dad94d4bacadec7
  foreign-agent parameters 1100 bindings 300 pending 0 pending-time 300
syslocation "1501 Wilson BLVD"
syscontact "Christina Antonetti"
snmp-server new traps
vpdn group pptp
  no ppp authentication PAP
  ppp authentication MSCHAPv2
stm dos-prevention enable
stm vlan-mobility disable
stm strict-compliance enable
stm fast-roaming disable
stm sta-dos-prevention enable
stm sta-dos-block-time 3600
stm auth-failure-block-time 0
stm coverage-hole-detection disable
stm good-rssi-threshold 20
stm poor-rssi-threshold 10
stm hole-detection-interval 180
stm good-sta-ageout 30
stm idle-sta-ageout 90
stm ap-inactivity-timeout 15
mux-address 0.0.0.0
adp discovery enable
adp igmp-join enable
adp igmp-vlan 0
voip prioritization enable
mgmt-role guest-provisioning
        description "This is Default Super User Role"
        permit local-userdb read write
mgmt-role root
        permit super-user
mgmt-user admin root b65b8ff25272bb5f9e17bea3f22d10e8560b34e4d81de262
no database synchronize
database synchronize rf-plan-data
ip igmp
ip router pim
ads netad mode disable
packet-capture-defaults tcp disable udp disable sysmsg disable other disable
end
Retired Employee
Re: AP70s do not register to Controller 800! Help!!
ArubaOS version 2.4 is quite old and is not supported anymore. My suggestion would be to upgrade the controller first and then troubleshoot.
Do you know what OS version are the APs running?
HT
Since the controllers and aps are old, they are no longer under a support contract.  Is there somewhere I can look to get an updated OS for the device?  Also, since I cannot get into the APs, I cannot tell what version OS they are running. We are in a bit of a pickle with this so any assistance is welcomed.
Since you have a 800, I would combine two articles:
First, to connect to the console on those APS:
How do I use the SOE feature for the 2400 series controller? https://kb.arubanetworks.com/app/answers/detail/a_id/348
Second to purge them:
How do I restore an AP to factory default? https://kb.arubanetworks.com/app/answers/detail/a_id/160
