Regular Contributor I
APBoot Commands / Problem with APBoot 1.0.8.3 on AP124
received some faulty AP124 with 0xFFFFFFFF "image invalid" , i tried booting up on OS 6.1.3.4 , i did "purge , save , boot" also "clear OS" , didnt help . i attached the AP124 some some legacy 5.0.4.7 controller and voila the AP properly booted and upgraded it's image in provision.
I dont have a clue at the moment ( i do such things once a year perhaps) how again i can upgrade the boot OS so it's valid for newer 6.x controllers. normally this should work automically but not in my case.
Again :
-AP124 had 0xFFFFFFFF invalid image , reboot loop in OS 6.x
-attached to OS 5.x controller, AP comes properly up and i can provison him ,.
in the APboot Menu i see "upgrade" but i dont know the syntax , perhaps too dumb today (as always)
thanks!
